        Publisher: Futuremark
 3DMark is arguably the most popular synthetic benchmark around today.
The DirectX 11 portion, Fire Strike, comes in three flavours: Fire
Strike, Fire Strike Extreme and Fire Strike Ultra, which run at 1080p,
1440p and 4K respectively. All cards are tested in Fire Strike and
Fire Strike Extreme using the
 default settings. Anyone can download and run the Fire Strike benchmark
for free, so you can easily compare your own system's score with those
you see below. You'll need to pay to unlock
Fire Strike Extreme yourself, however.
3DMark Time Spy, meanwhile, is a DirectX 12 benchmark that runs at 1440p. It is designed to properly utilise the advantages of the DirectX 12 API. The benchmark is available for free, but you'll need to pay to change any of the settings, including the resolution. We use the default settings, so you should easily be able to compare your score.
 VRMark is another synthetic GPU benchmark from Futuremark, this time
specifically designed to assess a system's ability to handle VR gaming,
although no VR headset is required. The Orange Room test assesses
whether a system is capable of meeting the current minimum requirements
for an Oculus Rift or HTC Vive VR headset. We run it at default
settings, so users can easily compare scores here to the free version of
 this benchmark where settings cannot be changed.
